how do i remove spoiler?
Old 11-19-2007, 07:13 PM
05bLkCoBaLtSs's Avatar
Just a quick question that might seem dumb to a few of you out there but i attempted to remove my spoiler and had failed. i had removed all bolts (4) and it is held together with some kind of apoxy or glue. what is the best way to get this off without risking the paint of the trunk. i know it will leave holes but how i get the spoiler off and all that gunk off? anyone have a good way to go at it? please PM or email me nathankarina@yahoo.com
Old 11-19-2007, 07:17 PM
chevysalesman614's Avatar
use fishing line, like a cheese cutter. move it back and forth to slice through the glue.
redlineblueline's Avatar
or dental floss
campo165's Avatar
or a chain and some beer
Old 11-22-2009, 07:05 PM
Heatwavedave's Avatar
chain and beer FTW! ill let you borrow my pickup truck!
Old 11-22-2009, 07:09 PM
mofofernando's Avatar
use a heat gun as well but dont hold it in 1 area too long. take your time it takes a while. i got impatient and put 2 small dents in my trunk. haha
Old 11-22-2009, 07:59 PM
Nighthawk243's Avatar
Chain and Beer
Seriously though, it is about the same process as debadging... just on a larger scale. Take a hairdryer to warm up the tape, then dental floss. (Don't use a heat gun... too risky if you're inexperienced with it.)
Once the spoiler is off, use goo gone to remove the excess.
Old 11-22-2009, 08:21 PM
i used goo gone as well. if you use it dont let it sit on the paint too long. i heard it can eat the clear coat. but thats hear say since it didnt affect mine
Old 11-22-2009, 08:48 PM
Joe Schulte's Avatar
Undo 4 nuts, have muscular friend watch you struggle, meanwhile multiple pieces of fishing line break, you flex it up and down no bulge.
A beer later, no care in the world, you both rip it off with stupid force and cheer in success.
Meanwhile people around your apartment complex walk faster and stare strangely.
You noticed little dings from blunt force, cover holes with body colored plugs or electrical tape. Then crack another beer for success. GM, **** your high-rise.
Old 11-23-2009, 03:33 AM
For anything petroleum based as far as removers go, it is a good idea to rinse the area then apply wax after using it. What happens is products like goo gone and wd40 or gasoline (Old geezer trick) strip the wax off of the vehicle. This is one of the reasons why the area under the fuel filler door tends to bubble and corrode first: The gasoline strips away the wax and removes the protection the paint has.
Old 11-23-2009, 03:37 AM
Rattlesnake Race Shop
USMCFieldMP's Avatar
Or you do like I did... find someone with an absolute base model, and swap them.
Wingless base models seem to be a thing of the past though.
Old 11-23-2009, 04:16 AM
ff_drift_lol's Avatar
hahaha! great post.
use a heat gun wisely. be patient and keep lifting pressure on the wing. eventually it will start to come up and you can pull it off. I recommend using a hair dryer so you don't burn paint.
go to a body shop supply and buy an "eraser wheel" for 20 or so bucks to remove the remaining glue. compound with 3000 grit and plug 'em!
soccerkid13
01-11-2016 10:25 AM
Slick_Nick
09-28-2015 09:15 PM
Extreme Dimensions
09-24-2015 05:24 PM
katahdin_lubricants
09-20-2015 07:24 PM
Getaway_Driver
09-08-2015 09:41 AM
Quick Reply: how do i remove spoiler?
