K&N cold air intake
how does everyone like their k&n?? just purchased mine from turbo tech today! curious to see how soon i get a cel. i had the intake mod up to this point which worked and sounded great but now want to complete the set-up with a real system.
are the intakes the way they appear as advertised? i thought the orginal early models were black, but now they have different colors to choose from...?? i was torn between choosing between the k&n and injen. i chose k&n b/c i feel a lot more confident with their support and quality, plus being the 'original' makers of a cai i wanted that classic mod as well. is a true cai louder than the airbox mod?
Injen always have and are polished OR Gloss Black for the 2.0
I've had my K&N in for a little over a year now. I love it, I've never thrown a CEL. Don't listen to all those people that bash it cause its not a dry filter, saying that the oil is causeing there MAF(or whatever sensor they say it messes up) sensors to throw a CEL. I clean and re-oil my filter about once a month and never had a single problem. It does make the charger whine a lot louder.
I have had a K&N for about a year now on my 2007 and there is only one problem I saw with the fit. the problem is that the metal that K&N uses is soft so where the CAI is you may get rubbing either on the abs lines or the ecu's heat sink because of the way i installed mine I did not want to mess with the abs lines so it rubed against the ecu to fix the problem I used a rubber and steel hoes clamp that you can buy at home depot for just that added protection. It will however rub the ecu heat sink on the corner but this is ok I have never had any trouble with this.
z28addiction
09-28-2015 12:03 AM
OrangeCoba
09-25-2015 06:06 PM
