Positive & Negative Rear Speaker Wires
Old 06-23-2007, 11:47 AM
biniecki's Avatar
Ok here's the deal. I have a 06 LS without premium sound or any of that its just the basic stock stereo. I want to install my subs in it by hooking up a line converter to the rear speakers. However I need to know which wires are positive and which are negative. I tried to figure it out using the cobalt radio pin out sticky but it was down right confusing. Thanks
Old 06-23-2007, 11:58 AM
SilverBalt's Avatar
usually i think the black is a ground and the white is the power, just hook them up and if it dosent work change it around
halfj99's Avatar
i bealive the negatuve usually has a black line on the colored insulating rubber
Old 06-23-2007, 12:02 PM
UnstableSS's Avatar
if you hook it up and your speakers bounce in rather than out you have the wires backwards.
Old 06-23-2007, 06:19 PM
marerick007's Avatar
Try this out...should be the same even for our cars...
GENERAL MOTORS
P o w e r
Memory (+12v Constant) Orange
Ignition (+12v Switched) Yellow
Ground (-) Black
Illumination Gray
Dimmer Brown
Power Antenna Pink
S p e a k e r s
Right Front (+) Light Green
Right Front (-) Dark Green
Left Front (+) Tan
Left Front (-) Gray
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Left Rear (+) Brown
Left Rear (-) Yellow
Old 06-23-2007, 10:47 PM
Xavipheus's Avatar
The sticky is a little complicated, but if you read it eventually you will get it. However what that guy said above seems right, i thought i remember blue being on the left rear speaker though...hmm
Old 06-23-2007, 11:10 PM
I'm old school
Halfcent's Avatar
While there are some standards about what color wire means what, there are always differences from one to the next. However...
I haven't tried this myself on my own Cobalt yet, but if you look at the actual terminals on the speakers themselves, sometimes the manufacturer labels the polarity. Try that.
Old 06-24-2007, 12:07 AM
biniecki's Avatar
GENERAL MOTORS
P o w e r
Ground (-) Black
Illumination Gray
Dimmer Brown
Power Antenna Pink
S p e a k e r s
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Thanks I actually thought I hooked it up correctly but looking at this shows me know that I have it backwards. It still works even hooked up wrong but I will switch it just so that it is correct.
Old 06-24-2007, 12:33 AM
No prob! Hit me up with some rep!
Old 06-24-2007, 01:03 AM
biniecki's Avatar
Well another member on another site said that you i had it hooked up correctly. where did you get your information from. It works how i have it and he said its correct. If it was wrong how would I know for sure if it was incorrect?
Old 06-24-2007, 01:33 AM
Um, if you just type in GM speaker wire colors in google, you'll find a bunch of sites that list what I posted. If I'm not mistaken, it will work if you have them swapped, but I'm sure its not a good way to leave them. If the colors did match up, I'd make them match the list I posted.
Old 06-24-2007, 11:27 AM
biniecki's Avatar
Thanks. I looked it up in google like you suggested and it found one specifically for my car that had all the same colors listed. It was like you said, they are backwards. Sorry for doubting you.
Old 06-24-2007, 12:32 PM
Bandit2941's Avatar
If you have it hooked up with reverse polarity it will still work, but the subs will be "out of phase" from the other speakers. Sometimes it actually sounds better to run subs out of phase but generally not. You can just play with switching the polarity until it sounds best to you and leave it that way.
Old 06-24-2007, 08:54 PM
5150studios's Avatar
Installer trick - get a AA battery.
put a piece of wire on either end. you can hold it in place with electrical tape. touch the bare ends of each wire to the speaker terminals. the speakers will push out if you have the positive and the neg hooked up correctly. This is a sure way to figure it out. Sometimes online color codes are not accurate
Old 10-13-2008, 07:48 PM
Maupin SS/SC's Avatar
You can just go to best buy and for $12.48 buy the gm adapters and just plug them in???? Why deal with wires
Old 10-14-2008, 12:00 AM
EmperorJJ1's Avatar
save urself 12.48
Tupp
2.2L LAP Performance Tech
01-02-2016 12:04 PM
dennis69
10-20-2015 07:39 AM
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
09-26-2015 06:44 PM
Quick Reply: Positive & Negative Rear Speaker Wires
