Programing key for 06 Cobalt Lt
Old 04-30-2007, 09:50 PM
Steamboatgal's Avatar
How can I program a key for my 06 Cobalt LT? I have looked in the owners manual and came up with nothing.
Old 04-30-2007, 09:51 PM
CTORANGESC's Avatar
Im pretty sure you can't do it yourself. You need the GM scan tool to do it.
Old 04-30-2007, 09:58 PM
How can I save money on a keyless remote?
Thanks,
It's better to know that the $80+ tax spending for a key is not preventable. Have not spent the money yet. But it will be long due.
I bought the car used...but love it...and it didn't come with any spares or a single remote.
06 Cobalt LT
Needing a keyless remote....any leads on saving $ for this?
Last edited by Steamboatgal; 04-30-2007 at 10:08 PM. Reason: Automerged Doublepost
Old 04-30-2007, 10:14 PM
I'm old school
Halfcent's Avatar
Try ebay. I bet you could find one there.
Old 04-30-2007, 11:17 PM
bluecobaltss06's Avatar
Actually I'm pretty sure you can do it yourself if you already have one programmed key. I know it works on the new Impala's I don't know about the Cobalt's but you can give it a try.
Put your original, programmed key in and start the car. Let it run for about thirty seconds, NOW AS FAST AS YOU CAN, shut the car off pull the key out, and put the new unprogrammed key in and start the car. It should start. If it doesn't your gonna need to take it to a dealer.
^^That's for the key, but if you mean you want to program a key fob, then yes a dealer or someone with access to a Tech 2 has to do it.
Old 04-30-2007, 11:24 PM
06_SS_S/C's Avatar
You can do it yourself. fr33k explained it in another thread, here is the link.
https://www.cobaltss.net/forums/show...09&postcount=5
Old 01-31-2008, 01:32 PM
alejandrogutierrez's Avatar
have no keys though
Old 02-01-2008, 12:01 PM
fr33k's Avatar
If you have no keys at all, you can do what they call a 30 minute relearn. That's after you purchase a key cut by code from your GM dealership. Dealerships can get your VIN number (and probably proof of ownership) and request a keycode from GM. Watch out though, most dealerships try and charge you an arm and a leg to do that and try to tell you it costs them. THEY ARE LYING!!!!! GM doesn't charge to access the key code information. It's all on GMDealerworld. That's just another way for them to try and make more money.
For the person earlier, $80.00 for a key is almost double the list price for the keys. Regular GM list price is $41.99. The rest of it must be the fees that some places add on. We, where I work, don't add on those stupid fees to keys.
Back to the relearn process. After you get your key from a dealership, it wont start your car YET. Make sure that your battery is pretty charged up. Keep most of your accessories turned off. And turn off your automatic headlamps. You don't really want your battery to go dead during this process.
1)Insert the cut key into the ignition and turn it to the "ON" position. DO NOT TRY AND START!!!
2)Leave it turned on for 10 minutes. Around the 10 min mark, your security light on your dash will go out.
3)Turn your ignition switch off but DO NOT remove the key. Leave it off for 5 seconds.
4)Do the same for step 2
5)Do the same for step 3
6)Do the same for step 2
7)Do the same for step 3
8)After you have done the THREE 10 minute cycles, I usually turn off the ignition and remove the key from the cylinder.
After that, it should start the car. Remember, the steps are 10 minutes on, 5 seconds off, 10 minutes on, 5 seconds off, and then 10 minutes on.
dennis69
10-20-2015 04:49 PM
satisfied
10-19-2015 12:35 AM
Shane H
09-20-2015 11:56 AM
Gugi96
09-15-2015 12:24 AM
jthwjde
09-07-2015 09:24 AM
Quick Reply: Programing key for 06 Cobalt Lt
