Cylinder 1 Misfire
Old 04-14-2007, 01:40 PM
SStud's Avatar
Question Cylinder 1 Misfire
Alright like the title says i'm getting a Cylinder 1 Misfire. The wierd thing is it's only happining while i'm at idle, parked in the parking lot. It throws the code a good five minutes or so after i'm done driving. What causes this and how can i take care of it. I've got the ZEX plugs in it and they don't quite have 2500 miles on them yet. So any advice? Later.
Dave
Old 04-14-2007, 01:47 PM
Witt's Avatar
Is it always a P0301 code or have you ever got any other cylinder to show a misfire code?
If its always number 1, check the plug, coil, injector, and do a compression test.
If you've got another cylinder to show a misfire before, its probably in the tune. Too much or too little fuel or a bad MAF or o2 sensor.
Old 04-14-2007, 02:51 PM
g5mike's Avatar
I have the same problem just at idle,think its my cams pissing the computer off,cause I just had my head and injectors done
Old 04-14-2007, 03:59 PM
jeremie's Avatar
take out the spark plug and swap it with another and see if the missfire moves. if not, swap the coils and see if it moves. if still nothing, swap the injectors around.
honestly its probably not compression related, other wise it would be a horrid miss and it would happen all the time. its probably just a spark plug, zex plugs are **** anyways. i'd put in some NGKs
Old 04-14-2007, 07:14 PM
DTM2188's Avatar
I had the same problem, but in cylinder #4. The problem with mine was a vaccuum seal leak.
Old 04-14-2007, 08:43 PM
SStud's Avatar
It is the only code i'm throwing, and the car runs strong when i'm driving it, but it just doesn't like to sit and idle i guess. I'll take a look at the plug and coil to see if i can see anything outa the ordinary though. Would a bad Injen Intake do this (The Notorious Slice)?
Old 04-14-2007, 09:14 PM
DTM2188's Avatar
Mine did the same thing, no power loss at all, but rough and bouncy idle.
Old 04-14-2007, 09:25 PM
SStud's Avatar
Can you elaborate on this one? I wanna check it out and get it taken care of it.
Sean Cummings
03-09-2018 12:26 AM
717ssbalt
10-02-2015 04:01 PM
09-28-2015 12:51 PM
SlowSaturn
09-28-2015 11:03 AM
Getaway_Driver
09-08-2015 09:41 AM
Quick Reply: Cylinder 1 Misfire
