Turn Signal won't cancel.
Old 04-07-2007, 10:50 PM
hectanooga's Avatar
Anyone else had this happen to their Cobalt? It started this morning and it's really annoying. Gotta take it in to the dealership... again.
(My wife is so fed up it's probably going to be gone within the month.)
Last edited by hectanooga; 04-09-2007 at 01:08 AM. Reason: Cause I'm an OCD spelling and grammar Nazi.
Old 04-07-2007, 10:56 PM
Get low
biohazard's Avatar
like when u turn the wheel back? mines does it
Old 04-07-2007, 11:47 PM
rickyw's Avatar
wow weird
Old 04-07-2007, 11:52 PM
I'm old school
Halfcent's Avatar
Failure to auto-cancel. Yes, mine does that every now and then.
Old 04-08-2007, 11:45 AM
hectanooga's Avatar
I think something physically broke in the steering column. Usually you can hear the tabs clicking when the signal is on and you are turning your wheel. Now, I don't hear that. I'll know for sure when it goes into the dealership this week. I was curious how widespread this problem was, if at all.
Old 04-08-2007, 11:48 AM
kissmySS's Avatar
Ya there is a switch inside the column that is most likely broke.. Take Er in..!
Old 04-08-2007, 11:07 PM
I'm old school
Halfcent's Avatar
The "sticks" that are mounted to the column are conplete units. That can literally be unplugged and removed from the column as separate unit. The cancelling mechanisms are within each one. The column itself just has the cam trigger.
Old 04-08-2007, 11:12 PM
MachiBLue's Avatar
I've had that happening in mine for a couple of months now. I havent taken it to the dealer yet, so I don't know whats wrong with it.
Old 04-09-2007, 06:50 PM
hectanooga's Avatar
Just got back from the dealership...
"SIR Coil canceling cam plate separated from coil, verify concern. Remove steering column covers and turn signal switch for access. Inspect and found cam plate separated from coil. Necessary to SOP coil. Reassemble vehicle."
Thats verbatim from the service invoice. Took it in today to get a new radio and fix my turn signal auto-cancel. I'm waiting on them to special order the part to fix that, so I get to go back again when it arrives. (And they need to fix my dash because they jacked it up when they put the radio in.)
Old 06-21-2009, 01:43 PM
pixarwolf's Avatar
I'm on my second Turn Signal switch/stalk for this - for a 2006 Cobalt LS - with 85K+ miles - I'm looking to replace the unit myself, wondering how hard to do this is? - (don't want to be messing around the airbag)- my dealer closed up last year and not looking to start a relationship with another.
From looking at the part I'm figuring it's just a few screws - and a wire - would I be able to use a Chilton/Haynes manual ?
Old 06-21-2009, 02:01 PM
Nighthawk243's Avatar
Yeah, take it in. The part on the controls that catches on the gear set in the steering column is broken.
Old 06-21-2009, 02:23 PM
pixarwolf's Avatar
so it would be in the switch module itself ? -
I'm very tight on money these days (who isn't) so no trips to a $tealership if I can replace a part myself-
only going to keep this car another year until I pay it off - (she's in very bad shape)
Old 06-22-2009, 05:45 PM
I'm old school
Halfcent's Avatar
Each column control lever is a replaceable unit. Just open up the colum (3 screws underneath) and you will be able to plainly see the units and how to take them out. It's very easy.
Old 06-30-2009, 03:25 PM
pixarwolf's Avatar
just replaced the switch unit - amazing all the plastic the car is made of - and then the turn signal says "MADE IN CHINA" ahh that explains everything -
Old 07-17-2009, 06:48 AM
chadnky's Avatar
I have been having problems with my turn signals not working correct. When I first got the car at 36,000 miles it wasn't that bad however it did get worse and now my turn signals won't cancel at all after 68,000. Now I also notice that when I turn my wipers on high they sometimes don't come on. Does anybody know how much it cost to replace the part for the turn signals? And does anybody know what could be wrong with my wipers?
Old 07-18-2009, 03:22 AM
bruizer69_210's Avatar
I had this problem too. It was kind of easy to fix. Take the swith out and take it apart. there is a straight strip of metal that the use as a spring that you need to bend a bit to make it a bit stronger and that fixed my problem.
Old 06-29-2011, 06:51 PM
CobaltVenomSS's Avatar
Does anyone knw the part number for the turn signal lever??? Mine won't stay on when the left one is on and won't cancel when the right one is on .....
Old 06-29-2011, 06:53 PM
Refractor's Avatar
You should just keep turning. Problem solved.
Old 06-29-2011, 07:25 PM
Tomtwtwtw's Avatar
Didn't even know this thread existed, but I'm glad it does. I have 40k miles on my '08 SS and my 2nd turning signal level is going out, and this time I'm out of warranty. Good to know it's a simple fix.
Old 06-29-2011, 08:02 PM
I just need the part number so I can get it off gmpartsdirect lol
Old 06-29-2011, 09:32 PM
C_A_D88's Avatar
Could just get a new switch outta a scrap yard for cheap , happened to
Me a few times under warranty, replaced the switch both times
Old 06-30-2011, 05:24 AM
06SS ALL DAY's Avatar
if your still under warranty then take it in to the dealer. if not, its going to cost you 3x more to have them replace it when you can do it yourself in 20 minutes.
Old 07-01-2011, 11:43 AM
jlong3382's Avatar
I changed my steering wheel and have had this problem intermittently ever since.
Old 07-01-2011, 01:04 PM
CrateEngineDepot's Avatar
LINK
In stock, Ive installed these, they are not hard to do.
Old 07-01-2011, 01:06 PM
Tomtwtwtw's Avatar
Originally Posted by CrateEngineDepot
LINK
Sweet! I'm going to bookmark the product page as I'm sure I'll be visiting it soon enough.
Quick Reply: Turn Signal won't cancel.
