[PCM] P0230 - Fuel Pump Relay Control Circuit
Old 11-16-2006, 12:41 PM
bdwarr6's Avatar
[PCM] P0230 - Fuel Pump Relay Control Circuit (Pending) (Current) (Immature)
Since my thread was so general and long
I am making a new one, the car is all done accept this error
The fuel pump primes i hear it buzz/humm it has pushed fuel back into the fuel rail i check the bleed off but the car will not fire
Would anyone happen to know where the fuel pump relay is?
Old 11-16-2006, 12:42 PM
HackAbuse's Avatar
Check your owners manual, it must be in there
Old 11-16-2006, 01:04 PM
bdwarr6's Avatar
nothing in there
Old 11-16-2006, 02:48 PM
M88ArRamadi's Avatar
HA HA....I can finally help you for a change!!
Here you go brother!
BTW....thanks for introducing me to Scott at Cobalt performance parts
Old 11-16-2006, 07:24 PM
chevytech's Avatar
you said you replaced all the relays right? and after you replaced them you got this code correct? check to make sure the relay is in properly and the right relay for that matter
Old 11-16-2006, 07:38 PM
bdwarr6's Avatar
No, sorry for not updating replacing the relay fixed this I am cell free my engine wont fire though ....
So im out of leads accept i have no spark
Old 11-16-2006, 08:17 PM
chevytech's Avatar
you could test this by going to a good known ground on the block or just touch the ground strap to the block when attepting to fire it
Old 11-16-2006, 08:32 PM
HackAbuse's Avatar
I always use my motor mount as a ground
Old 11-16-2006, 08:39 PM
chevytech's Avatar
wrong side of the engine but that would work if the strap was long enough. i meant to post that last post on the other thread but im tanked so i have an excuse
05-28-2022 03:47 AM
no_ss
10-18-2015 11:58 PM
DocSvensk
09-27-2015 02:24 PM
Adiaz1ss
09-26-2015 11:51 PM
roth
09-26-2015 12:16 PM
Quick Reply: [PCM] P0230 - Fuel Pump Relay Control Circuit
