Driver's side headlight not working (low beams)
Old 07-25-2012, 11:23 PM
Black05's Avatar
Hey guys, acquired a new problem with the slowbalt, hoping for a relatively quick fix.
Ok, so here's the problem. My driver's side headlight will not work for any reason. The bulb isn't the problem (switched with passenger side), all of my fuses are ok, and it's all been disconnected and re-connected properly. I even replaced the entire assembly with another cobalt's headlight, and it still won't function.
The orange DRL is still working, the brights both work, but the low beam will not work. I've tried just about everything I know to try, so hopefully you guys can point me in the right direction.
Thanks,
Ian
Old 07-25-2012, 11:36 PM
TheSlowGT's Avatar
if its a regular halogen bulb still, the filament for the low beam might be burnt out. had that problem once before. there's two coils in the light, one for the high beam, one for the low, if one looks like its broken in any way, its the bulb.
Old 07-25-2012, 11:45 PM
Black05's Avatar
You know what, I just figured it out. The connector on the car side for the assembly has a pin that's broken. What's the best way to go about repairing that pin?
Old 07-25-2012, 11:51 PM
TheSlowGT's Avatar
errrr not too sure haha.
Old 07-26-2012, 11:29 PM
Black05's Avatar
LOL. I ended up taking a tiny flathead and bending the pin so that it could come into contact with the assembly side, and BOOM it works now!
I had a good feeling about that! #Ghettofixes
Old 05-09-2016, 12:35 PM
TylerLiburdi's Avatar
Hey man I'm running into the same problem, could you be more specific on what pin you're talking about? Maybe add pictures?
Old 05-09-2016, 04:08 PM
Kolt's Avatar
Thread revival much? lol here is pinouts of the connectors. all you need is a test light to see if you have voltage at the correct pins at the right time. also includeds wiring diagram.
HMP Tiff Hotspot Viewer.pdf
gsi.ext.gm.com - showDoc.pdf
Bluelightning
11-11-2015 02:41 PM
chefhhr
10-26-2015 10:36 PM
Cptnslo
09-24-2015 09:32 AM
jonnycat
09-19-2015 12:58 PM
ROADKONE
09-09-2015 02:32 PM
Quick Reply: Driver's side headlight not working (low beams)
