cooling fan wont turn on
Old 10-14-2011, 11:21 PM
Axelthered05's Avatar
so about a week ago I was siting in my car right before work with the car just idleing listenbing to music and what do you know there was a loud noise and the car started violently shaking so I turn off the car and pop the hood to look for the cause and I see coolent leaking out of my radiator I had no idea what hapened so long story short one of the blades of the cooling fan came off and hit the radiator and i ended up replacing the cooling fan radiator and the condensor I finaly got everything back together but the cooling fan does not turn on evan when the coolent reaches 220 im at a loss I have replaced the relay, fuse and it still wont work any ideas what else I can try?
oh and before you ask no there are no codes
here is a link to some pics
Other STUFF | Facebook
Old 10-15-2011, 08:11 AM
Coblasts's Avatar
The fuse is most likely blown from when the blade stalled the motor.( jammed into the rad)
Old 10-15-2011, 10:22 AM
ItalianJoe1's Avatar
Agreed, check the fuse.
Old 10-15-2011, 05:28 PM
I replaced the fuse and the relay but still nothing any other ideas?
Old 10-15-2011, 06:12 PM
tpete763's Avatar
MY ground wire on my cooling fan was not connected properly and had to be rewired/grounded. My fan didn't hit my radiator though, it just stopped working one day. check the wire connections.
Old 10-15-2011, 07:37 PM
Coblasts's Avatar
Pull the connector for the fan and see if you have voltage to ground on the connector using a 12v test light or a meter.(turn the car on and the aircon,this will turn the fan power on)
which car do you have
2.2 or 2.4
Old 10-15-2011, 10:35 PM
found the problem the grounding wire was not fully inserted into the conector, i must have yanked it lose when I removed the conector from the old fan
thanks everyone for your help
Old 10-15-2011, 11:36 PM
tpete763's Avatar
No Problem! Glad yours was easy to find lol Mine was a bad connection at the ground point on the motor when I got it fixed.
06MetallicBalt
08-17-2021 03:40 PM
Solaris99
28
03-15-2017 01:22 PM
dennis69
10-20-2015 04:49 PM
roth
09-26-2015 12:16 PM
Quick Reply: cooling fan wont turn on
