cobalt 2.2 vs ss 2.4 cobalt
Old 06-30-2006, 09:01 PM
slick54's Avatar
Question cobalt 2.2 vs ss 2.4 cobalt
is there that big of a difference in their preformance
Old 06-30-2006, 09:15 PM
Cman06sssc's Avatar
2.4 has about 30 h/p diff plus more TQ. enough to squezze by ya on the street.
Old 06-30-2006, 09:22 PM
roccityroller's Avatar
i ran one on the street awhile ago, it was auto, i was stick it was pretty even, but i put about a car on him off the line and then he pulled me after that
Old 06-30-2006, 09:39 PM
Clmbngfrk18's Avatar
good to know my buddy is trying to get a 2.4 i think with my intake and exhaust and the fact he weighs like 100 pound more than me it should be close
Old 06-30-2006, 10:00 PM
g5mike's Avatar
When your bud is not looking put some weight in his trunk
Old 06-30-2006, 11:05 PM
1SloBowtie's Avatar
I ran a stock 2.4, man, against my 2.2 man, I/E and I hung with him. We shut down at 95 and his front bumper was at my drivers door. The 2.4 may have 26 more hp stock for stock, but the torque difference is minimal, 155 VS 163. But as far as stock for stock, same tranny setup and based on sheer power, 2.4 is better, that's why it's called an SS...
Old 06-30-2006, 11:13 PM
avro206's Avatar
way more top end power on the 2.4L. If its the same trans 2.2 vs 2.4L its no contest. Not real far off but still no contest
Old 07-01-2006, 12:00 AM
joeworkstoohard's Avatar
off idle, the 2.4 actually makes less power than the 2.2 once teh VVT starts doing it's magic the motor really comes alive. if you wind out a 2.4 it just feels a lot "sportier" than a 2.2 also, coil on plug ignition, forged interals, few other goodies, it's just an overall more performance based engine. with that said, the 2.2 is a lot quieter and a hair smoother.
Old 07-01-2006, 12:40 AM
BlueThunder2006's Avatar
I own a bone-stock 2.2 and have driven a 2.4 with Injen CAI, both auto. The 2.4 does have more top-end, but it's not like going from a 2.2 to a 2.0SC. Off-the-line, they're close, but the 2.4 will pull on the 2.2 at about 1/8 mile, I'd guess. I'd like to run them against each other AT THE TRACK to see 'exactly' how they compare, though.
Old 07-01-2006, 09:24 AM
avro206's Avatar
I'll disagree with that--the torque curve on the 2.4 is higher at lower rpms then the 2.2--according to GM dyno graphs
Old 07-01-2006, 10:35 AM
06G5GT's Avatar
Yep, the dyno graphs tell the story between the two much better than comparing peak torque. If you compare the peak torque ratings for both, it seems like little difference in 155lbs-ft vs 163lbs-ft.
Looking at the dyno graph, we can see that the 2.4 starts making 150lbs-ft at an early 2400rpm and stays above 150lbs-ft all the way till 5800rpm. The 2.2 hits 150lbs-ft at 3800rpm and only stays there till 5100rpm.
Also looking at the 2.4 plot, it does make it's peak hp at 6200 but it doesn't spiral downward right after that. It keeps making power all the way to redline.
The only real difference between the two is the VVT. I wouldn't be surprised to see VVT on all Ecotecs in a couple years.
Old 07-01-2006, 02:57 PM
lol ill just get him to drive with his girlfriend lol
Old 07-01-2006, 03:08 PM
I am just going on what I've heard.
Old 07-01-2006, 09:21 PM
IonNinja's Avatar
it should be close but he should still pull on you, you're gonna need just a little more power to actually outpower one and not just beat the driver.
i think u'd have alot better chance with a good header too
Old 07-02-2006, 01:19 AM
NewCobalt06's Avatar
Honestly he should pull on you but if you do have intake an exhaust and know how to really drive a 5SPD it should be dead even. You could possibly beat him.
Old 07-02-2006, 01:47 AM
I'm old school
Halfcent's Avatar
One thing I noticed above...
The stock automatic trans in these two cars does have one difference.
The SS model automatic has a higher ratio differential. The idea being to take the extra power and spin the wheels a little faster at the same RPM.
Old 07-02-2006, 10:26 AM
qcpursuit's Avatar
yesterday I had the chance to drive all the cobalt models(ls,lt,SS,SS/Sc with stage 2 and K&N) and after these tests,I would say that the SS/SC is totally in an other world but when it come to make the diference between the 2.2 and the 2.4(both with auto),there is not a huge difference.The major diff between to is on handling but for the rest with my 250$ springs and my 17' wheels im happy with my car.
Old 07-02-2006, 10:44 AM
dnbguy86's Avatar
Sorry to burst your bubble, but the final drive ratio is the same in both ss and non cars that use the 4t45e. It's 3.63 for the final drive
Old 07-02-2006, 11:36 AM
avro206's Avatar
even if it did---it cannot be at the same RPM with different gears.
Old 07-07-2006, 05:11 PM
I'm old school
Halfcent's Avatar
Ya know, you totally did burst my bubble. I confused the manual with the auto. I went back and checked, and the 4T45E Automatics are in fact completely identical across all the Cobalts. The manual on the base/ls/lt models however has 3.84 ratio while the SS has a 3.91 and the SS/SC has a 4.05. You win.
Old 07-07-2006, 07:27 PM
avro206's Avatar
I'll burst it again!
a 5 speed F23s have 3.84 ratio. I have said this numerous times before but Chevrolet.com has lots of errors on it. Go the gmcanada.com for the stright goods
Old 07-07-2006, 07:47 PM
bykryder83's Avatar
No Not Really But The 2.4 Has Some More High End Power And Torque,but Not Much...i Have Raced 2 A Auto And A 5 Speed And I Beat Them Both The 5 Speed Is A Little Faster Than The Auto But Not Much,so Basically A 06 5 Speed Ls Should Beat A 06 5 Speed Ss Coupe Any Day,its A Weight Thing The Ss May Have More Power But It Has More Weight Than A Ls Alot So There
Old 07-07-2006, 08:31 PM
g5mike's Avatar
Ive driven both and disagree
Old 07-07-2006, 09:33 PM
06G5GT's Avatar
26 hp more than makes up for any weight difference between the two. You caught a guy that couldn't drive. Anybody that test drove both before buying knows this.
Old 07-07-2006, 10:23 PM
Brandon97Z's Avatar
that 5-speed SS driver couldn't drive then. I can see you beating an auto those have been known to run a 16-15.5. But not a five speed sorry best i've seen one ls do is a 15.6 ,Several 2.4's have done low 15's, like 15.2ish.
Quick Reply: cobalt 2.2 vs ss 2.4 cobalt
