Replacing head gasket in 2.0
Old 02-12-2011, 04:05 PM
SSQT125J's Avatar
Question Replacing head gasket in 2.0
I need to replace the head gasket in my 06 ss/sc. (well my bf does) im trying to get a list together of everything & i mean everything i will need. can anyone help me out.thanks
Old 02-12-2011, 05:34 PM
06SS ALL DAY's Avatar
just go to zzp performance.com (google it), buy the head gasket and parts from there... your set chick
sugarcanejuice (11-13-2022)
Old 02-12-2011, 05:36 PM
nevermind saved you the b.s.
Cobalt & Ion ---> ZZ Performance
Old 02-12-2011, 05:46 PM
StevesBlack06's Avatar
cometic is the way to go but there is nothing wrong with getting another stocker... i actually know guys that prefer the stocker. youll have to take the cam gears off to remove the timing chain so youll need new cam bolts. they are torque to yield and shouldnt be re torqued. lots of ppl re use them but just use loctite when they put them back on. its always a good idea to replace your head studs not because you need to but because you already have it apart so why not get better ones. ARP head studs are the way to go in that catagory. other than that, everything can be reused or put back together unless something is slipping my mind. gotta be EXTRA careful when removing the cam gears so you dont skip timing on the engine. they make a cam gear holding tool but you dont need it if you have 2 ppl doing the work. one person just has to hold the cam in place w a wrench while the other person loosens it. be sure to un toque and retorque the head in the proper sequence aswell. i hope some of this helps
also when removing the head its much quicker to just unbolt the header from the downpipe instead of unbolting the header from the head... just pull the head and header off as one.
Old 02-12-2011, 05:55 PM
rnjmur's Avatar
While you have it apart you may as well replace the timing chain, guides and tensioner as well unless you have done it already.
Old 02-12-2011, 06:12 PM
SSQT125J's Avatar
thanks for the info guys!! i know hes done it before on a buddies but that was a little while ago so i wanted to be sure
Old 02-12-2011, 06:16 PM
mrbelvedere's Avatar
tensioner yes unless its thr updated one then no and no need chain sliders hell no
Old 02-12-2011, 10:48 PM
G11
G11's Avatar
here is a how to...it actually is a piston how to but you have to do essentially the same stuff to get the head off...there are a couple of steps that can be done different but for the most part follow this
How-To : Piston Install (LSJ))
Old 02-12-2011, 10:52 PM
alleycat58's Avatar
What someone else said, if you don't have the upgraded tensioner in there, now would be an ideal time to upgrade. It's not a "will I need it" part it's a "WHEN will I need it" part.
Old 02-12-2011, 11:05 PM
raptors_67's Avatar
Head gasket, head studs, crankshaft bolt is torque to yield so it needs to be replaced, i think that is all. Hardest part is getting the timing chain back on correctly and that tensioner back in properly. Other than that it's just a time consuming job, nothing really difficult about it. I replaced with the stock MLS 20psi on TVS, no issues to date.
Old 02-13-2011, 01:29 PM
yea the timing chain is always a good thing to replace... they stretch over time
Old 02-13-2011, 03:24 PM
SSQT125J's Avatar
what will the parts end up costing me total? around 500?
Old 02-13-2011, 03:42 PM
alleycat58's Avatar
Not sure how much the timing chain and new tensioner cost, but I think the head gasket and studs are like $150? Total should be less than $500 if you shop smart and don't buy through the dealer.
Old 02-13-2011, 03:57 PM
check out turbotech or allecotec for parts. they usually have good deals. zzp too
Old 02-13-2011, 06:52 PM
G11
G11's Avatar
ced has combo deals that are priced pretty good!
Old 02-13-2011, 06:59 PM
yezzir. forgot about them
Old 02-14-2011, 08:57 PM
raptors_67's Avatar
Pretty sure the parts cost me around 200 CAD.
Old 02-15-2011, 01:13 AM
InfraRedline's Avatar
Yeah I just got the HG kit from CED for like $156. Still need to order the crank pulley bolt, cam gear bolts, and tensioner. Waiting until I get the head back to order the rest in case I need something else.
Old 04-03-2020, 05:40 PM
Dave Hicks's Avatar
was that just parts and did you repair yourself?
05-28-2022 03:47 AM
justinchinn
10-02-2015 12:18 PM
Trav3480
10-01-2015 08:17 PM
09-28-2015 12:51 PM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: Replacing head gasket in 2.0
