View Poll Results: Average Coolant Temp. Driving and Sitting
185 or less
30
24.19%
186-190
46
37.10%
191-195
30
24.19%
196-200
18
14.52%
201-205
4.84%
206+
2.42%
Multiple Choice Poll. Voters: 124. You may not vote on this poll
What is your Avg. Coolant Temp
Old 06-24-2006, 12:44 PM
TWIZTED 2.2's Avatar
When im driving my coolant stays between 187-193 but, if im stopped at a light for longer than 1 min then my coolant climbs, highest has been 218
Old 06-24-2006, 12:46 PM
DreamZ's Avatar
Mine stays around 199 when Im driving or at a light.
Old 06-24-2006, 12:58 PM
uwishuhdmyecotec's Avatar
with the a/c on mine stay at 185, sitting at a light with the a/c off it goes to like 210
victoryredSC's Avatar
i'm normally running about 187-193 while driving. At a light it ranges from 190-195! At first i was worried but then i figured thats probably normal since most other cars don't have coolant temp gauge!!!!
Old 06-24-2006, 01:04 PM
BlueThunder2006's Avatar
Mine seems about normal- 190 or so while driving, 200-ish at lights.
If this seems high, keep in mind that both of my S10's ran at a constant 210, and never had any problems.
Old 06-24-2006, 05:47 PM
jokieman's Avatar
It's within Spec as long as it is within 185-230 range.
With the A/C on though it should really never go above 205 because the fan is on all the time when the A/C is running.
Old 06-24-2006, 06:02 PM
Since i put on the SRI to CAI back to SRI.. my AC wont et cold. if its over 75Deg outside
Old 06-24-2006, 08:52 PM
Coblt ss super's Avatar
mines stays in the 180 range never went above 195
Old 06-24-2006, 10:32 PM
RaineMan's Avatar
With the engine cover off... and A/C off... she'll stay in the 190's during normal driving... I've seen it climb to 210 when sitting at a light.
With the engine cover on... it runs around 200 when driving.... and 215 when stopped.
With the A/C on... It won't get above 190.
I'm beginning to seriously consider a new set of electric fans or a fan switch.
Old 06-25-2006, 12:15 AM
Blackout06LS's Avatar
196-200 Range anywhere.
Old 06-25-2006, 12:27 AM
tiny's Avatar
i bought a bottle of Water Wetter, works wonders
Old 06-25-2006, 12:56 AM
Allshot's Avatar
180-185 without mods. 190-205 with mods for some reason...
Old 06-25-2006, 03:03 AM
SilverSS/SC's Avatar
With both my fans set to run high speed all the time with HPtuners , and bottle of water wetter , my car hasnt seen over 185* since , regardless of the situation .
Old 06-25-2006, 04:12 AM
iso
iso's Avatar
mine stays around 187. but i was sitting in my g/f's driving waiting to pick her up (i was there for a while) and i looked at my temp gauge and it was at 226. i got scared and turned the car off. when i turned it on i got a "low coolant" message on the dic. took it to the dealer and they said nothing was wrong. haven't had it happen since.
Old 06-25-2006, 11:01 AM
Anybody know where to get the "water wetter"? trying to find it!
Old 06-25-2006, 11:18 AM
BlackSS05's Avatar
even better ? what is it? is it a direct replacement or an additive for coolant. My car stays below 190 when driving but i have seen it in the 2teens when sitting.
Old 06-25-2006, 12:35 PM
Jaysonk12's Avatar
183 seems to be my car's normal cruising temp.
Old 06-25-2006, 03:19 PM
tiny's Avatar
water wetter can be found at any local automotive store for around $10 after tax
Old 06-25-2006, 04:18 PM
05BlackCobaltSS's Avatar
hey iso, were you on an incline? b/c if you were, than the coolent just might have fallen below the senser. Just A Thought.
But, on topic. My car ran at 195-205 until i put the BKR7E's in. Now it's at 190-192 almost constantly, AC or no AC.
Old 06-25-2006, 07:19 PM
Dark-Fx's Avatar
Coolant is usually around 180-190. I've seen 236 before, but then the fan kicked on and it dropped considerably.
Old 06-26-2006, 02:15 AM
iso
iso's Avatar
nah, it was basically completely flat. the delaer said it may have been air in the lines... i don't know how that would happen but w/e.
Old 06-26-2006, 12:21 PM
p7x
p7x's Avatar
185 or less when driving and anytime the car is sitting but on the coolant just keeps rising.
Old 06-26-2006, 12:34 PM
alleycat58's Avatar
Driving around 187. Auto-x run it drops to 174. Sitting in traffic 224 is the highest I've seen.
Old 06-26-2006, 12:37 PM
memphisr24's Avatar
Mine stays around 189. In the winter it's around 180-183. The weird thing is, if I sit too long, it will go up to 227 (normal) and go back down (normal again). However if I sit again, it stays at 190. It won't go any higher, no matter how long the car sits running.
Old 06-26-2006, 04:18 PM
oaklandmr's Avatar
Mine is usually right around 190-195 or so. I've seen it get as high as 210 when stopped at a light but that the highest ive seen.
Quick Reply: What is your Avg. Coolant Temp
