Loose battery terminal
Old 01-18-2011, 01:54 AM
ronn's Avatar
Battery went dead on my trunk battery 09 SS TC. Turned out the negative terminal was loose and disconnected! The damn thing is a flimsy clamp that doesn't really fasten well. Anyone else experience this problem?
Old 01-18-2011, 10:13 AM
rogersj's Avatar
nope. did you have the cables off recently?
Old 01-18-2011, 11:47 AM
Erod's Avatar
moved! not general!
Old 01-18-2011, 04:21 PM
ronn's Avatar
It can move when fully tightened. The clamp is pretty thin and only tightens so much. Think it's vibrations..the strap wasn't on, so that may have been it...but the battery is fastened pretty well without it on. I put electrical tape over the top to help keep it from vibrating loose.
Old 01-18-2011, 06:14 PM
rogersj's Avatar
your best bet is to cut it off and solder in a new one or crimp one on
Old 01-18-2011, 06:33 PM
reddevil's Avatar
go to the auto store and buy a new battery cable clamp, you can buy one that clamps the cable to the terminal, make sure you get the right terminal for the battery post they are diffrent sizes the neg terminal is smaller.
Sl0wbaltSS
11-21-2018 11:11 PM
Solaris99
28
03-15-2017 01:22 PM
Tupp
09-30-2015 08:18 PM
grampss
09-27-2015 08:51 PM
c_m_shooter
09-27-2015 04:40 PM
Quick Reply: Loose battery terminal
