Code P0091
Old 08-22-2010, 03:18 PM
batboy's Avatar
Code P0091
If you suddenly go into limp mode and find a code P0091, check your wires first before taking the car in. It's possible the wires rubbed through and are grounding out (I think the wires in question go to the fuel pressure sensor or regulator). It's also possible that maybe your fuel pump is going bad, but check the wires first. It's well worth checking the wiring harness now even if you don't have a problem yet. If you see wear in the conduit, a little preventive maintainance is a good thing.
The other morning my Cobalt SS/TC went into limp mode, it lost power, chimed, check engine light came on, and it displayed the dreaded "eng pwr reduced" message. After checking to make sure the boost tube hadn't come loose (it had not), I pulled the code and it was P0091 (fuel pressure circuit low). I searched the forum and found out this code is common when the fuel pump is going bad. So, I was about ready to take it in to the stealership for a new fuel pump when I read a thread about a wire rubbing/shorting which can cause this code. I checked the wiring harness (see photos) and sure enough, it had rubbed through and was touching metal.
A little electrical tape and I was able to make it home ok. I figured out a more permanent fix this weekend. I cut a piece of plastic (like from a gallon milk jug) and wrapped it good with electrical tape at the rub point. This gives a little non-conductive armor to the rub point. You will probably have to disconnect a connector or two and pop off the harness holder to give you more room to wrap it with tape. Gently pull the harnes towards you to work. The rub point on my car was on the smaller harness right where it comes out of the larger harness.
This first photo shows the general area where to look (driver side front of the engine near the boost tube). The red circle marks the spot. You'll need to pull the harness away from that black metal bracket to see if it has rubbed or not.
This is a closer view showing the fixed harness. You can see the outline of the plastic piece I used for armor. Tape it up real good with electrical tape and you're good to go.
Matt10tc (04-14-2023)
Old 08-03-2011, 05:58 PM
PrincessTurbo's Avatar
Since nobody will take a look at this I am going to bump it because it's a HUGE issue ...
Old 08-03-2011, 08:36 PM
Ch1ck3n's Avatar
Sticky this noise.
Old 08-03-2011, 10:24 PM
MS3 2 SSTC's Avatar
Sticky!! I had the same issue and sure enough... It was the wires, slapped some electrical tape on there and I hope its fixed
Old 08-04-2011, 08:23 AM
Supercharged Guy's Avatar
Bump..this is nice to know
Old 08-04-2011, 08:43 AM
umrdyldo's Avatar
weird I don't see any rubbing there
Old 08-04-2011, 05:53 PM
asanti's Avatar
Good info to have since I had a similar problem a while back. It can affect us HHR SS owners as well.
Later
Allex
Old 12-05-2012, 11:49 AM
Alleynejl's Avatar
Good post
Old 04-21-2013, 01:00 AM
Soofisahab's Avatar
Thread resurrect! Sticky!
Old 07-16-2013, 03:48 AM
taintedred07's Avatar
Bump good info and will check out my harness.
Old 07-15-2014, 12:24 PM
droponikz's Avatar
i've been dealing with the same issue on my 06 SC and am looking for a complete new harness. I have been looking around for one but none of the parts stores seem to know what im talking about. I believe its just a TB wiring harness of some kind, anybody know otherwise?
Old 04-03-2019, 04:42 PM
Moe420's Avatar
good info! Saved me time and money
Old 11-06-2019, 01:42 PM
cobyc's Avatar
Did a wot pull 2nd nls to 3rd, smooth coast back down to 30 mph. Got the engine power reduced message, code was p0091. Cleared it and car was back to normal, full power no issues. CEL did not come back, but i Was still worried so i checked under the hood anyway, to be safe. Found I had an obvious short. When i wiggled that area of the harness it created small sparks. it was exactly where pictured. I did the same electrical tape bandage and plastic wrapped in electrical tape to stop it from grinding at the wires. So far so good.
Old 04-12-2023, 06:58 PM
Evan09's Avatar
Great info. I got the P0091 in the middle of a 4 hour trip. Added some tape and was able to drive without any issues for the rest of the ride. Great info.
Old 06-30-2023, 09:07 AM
Evan09's Avatar
I had a friend use a multimeter after the fact to test the harness after.
hondadubs
02-18-2017 05:08 PM
turbosmart4
04-18-2015 01:45 PM
zaxbak
09-17-2014 01:31 PM
cubaniche
08-15-2012 08:27 PM
mfdkhoff261
06-30-2011 05:12 PM
Quick Reply: Code P0091
