Roar coming from front wheel!!
Old 07-22-2010, 03:06 PM
jojot's Avatar
I have a roar/whine coming from what sound like the front left wheel, has anyone had this before or could tell me what it could possibly be? It's an 06 ls.
Old 07-22-2010, 03:22 PM
scottie's Avatar
wheel bearing
Old 07-22-2010, 03:24 PM
fredds-turbaltSS's Avatar
when you say roar, you talken bout like a lions roar?
mccullj's Avatar
x2 for the wheel bearing
jokin aside its a hub/wheel bearing
Old 07-26-2010, 03:06 AM
goeckeritz123's Avatar
mine is loud do you guys get a lot of road noise. how can i tell if its my bearings
Old 07-26-2010, 03:14 AM
Rattlesnake Race Shop
USMCFieldMP's Avatar
Jack the car up, grab the tire at 12 and 6, and try to rock it toward you. Shouldn't be any play.
If there is play... we've found your problem.
Old 07-27-2010, 01:35 AM
scottie's Avatar
If you take your wheel off, and turn your hub assembly you will be able to feel if your bearings are shot. It should be smooth and tight when they rotate.
And road noise depends a lot on what tires your running. I don't get too much noise from mine. Not a roaring sound by any means.
Old 08-02-2010, 02:39 PM
irishredheadpa's Avatar
I'm starting to have this same issue. I doubt its under the powertrain warrenty. Any idea how much this costs to get fixed or is this something that can be done by anyone with general auto mechanical knowledge
Old 08-02-2010, 03:01 PM
scottie's Avatar
Its not too hard. timken bearings for the non SS are like 180 I think. So probably around there or a bit more for the 5 stud.
You have to remove the wheel, caliper, possibly caliper bracket, rotor, and maybe axle nut? I haven't done one yet so I'm not 100%
Old 08-02-2010, 03:04 PM
umrdyldo's Avatar
^^^ i believe that's about it, Same as a lot of GM vehicles.
Old 08-02-2010, 06:51 PM
army_greywolf's Avatar
Yes it falls within powertrain warranty. They will argue that but the warranty states drive axle (complete) which includes bearing.
Old 08-02-2010, 08:32 PM
css9450's Avatar
Remove the axle nut, caliper, rotor, and then the three bolts that attach the bearing to the knuckle. If its not already loose, you might need to use a puller to get the axle free of the splines inside the bearing.
Disconnect the ABS wiring harness from the back side of the bearing, and then it should be ready to remove. After three winters in the salt belt, mine wouldn't come out easy so I wound up removing the entire knuckle from the car and having the bearing pressed out at a shop (I used some anti-seize on the new bearing so hopefully next time will be easier).
Old 08-02-2010, 08:48 PM
LS6Rally's Avatar
does the nosie go away around turns? specificaly in one direction? say when you take a right the noise gets quiter and when you turn left its louder? when the noise is louder, the bearing on the opposite side of the direction you are turning is the bad bearing.
Left turn with loud roar = RF wheel Bearing
Right turn with loud roar = LF Wheel Bearing
Old 08-03-2010, 07:50 AM
I took my car to the dealership today, they said it is covered but can't get my car in till Monday which is fine. I'm just happy I don't have to pay for a shop bill
Old 08-04-2010, 12:04 AM
ctn2mb's Avatar
is it covered under powertrain? cause my bumper to bumper is out lol
Old 08-04-2010, 02:01 PM
Yea its covered under the powertrain warrenty.
Old 08-04-2010, 02:53 PM
ctn2mb's Avatar
sweet i gotta go in tmw for my sunroof replacement so imma mention it
Old 08-04-2010, 09:01 PM
What happened to your sunroof?
Old 08-05-2010, 01:07 AM
ctn2mb's Avatar
alignment was off... they fixed the alignment and just incase it happens again they ordered a sunroof lol
Old 11-30-2010, 03:25 PM
jojot's Avatar
How can I tell if my car has abs or not? "Without driving and slamming on brakes to see if the wheels would lock up" just threw that in there because I knew someone was gonna say it. There are two diff. bearings abs and non abs.
Old 11-30-2010, 04:23 PM
LethalSS's Avatar
look under the hood, is there an abs module and lines?
look on the back of the wheel bearing, is there a connector plug for the abs sensor?
if the answers are "yes" then u have abs.
Old 11-30-2010, 05:21 PM
LS6Rally's Avatar
the ABS light on the dash should come on for a second or two wehn you turn the key "on"
Old 12-03-2010, 09:35 PM
4bangerwut's Avatar
u can also call the dealer and give them ur vin and they should be able to tell u. or in my case i called the dealer and they told me i had abs but when i removed my wheel bearing, no abs. so it saved me about half the money
Meadowvalien
08-17-2017 06:32 PM
chefhhr
10-26-2015 10:36 PM
Tupp
09-29-2015 11:07 PM
Cptnslo
09-24-2015 09:32 AM
dieGone
09-23-2015 10:20 AM
Quick Reply: Roar coming from front wheel!!
