Key stuck in on position! Car can't be shut off!
Old 07-07-2010, 05:50 PM
CRR
CRR's Avatar
I was coming back from the gas station today and when I got home and parked, I couldn't shut my engine off. The key is absolutely stuck in the onn position! It will not turn to the off position. I tried unplugging the negative side of the battery and the car still wouldn't shut off. Then I unplugged the fuel pressure fuse in the engine bay to shut the car off that way and it worked. I then left the negative side of the battery unplugged as well so I wouldn't drain my battery down overnight, being that the key is in the on position. I tested the car to see if it will restart and it does, so that is good atleast. I'm taking it to GM tomorrow morning to have them look at it and hopefully get it fixed. The only problem now is that the check engine light came on, I assume from unplugging the fuel pressure fuse. I'm worried that they are going to find my tune on it now with the check engine light being illuminated. I have no idea what the cause is. Do any of you guys have any ideas? Any input would be appreciated.
Old 07-07-2010, 05:52 PM
07SuperchargedSS's Avatar
You should have disconnected the postive man. The battery could ground out and as long as the positive is connected, it could still drain.
Old 07-07-2010, 05:53 PM
tony2toness/sc's Avatar
my brothers 2000 malibu does that you have to jiggle the key till it comes lose check the ring were the key goes is there anything lose there if not maybe something in side were the key goes in
Old 07-07-2010, 05:56 PM
heathkidder's Avatar
def. unplug the positive cable
Old 07-07-2010, 06:05 PM
CRR
CRR's Avatar
Alright, I just unplugged the positive side too guys.
Old 07-07-2010, 06:07 PM
is the key still in or did you take it out if you took it out put it back in and jiggle it to see were the problem is coming from
Old 07-07-2010, 06:10 PM
Alleynejl's Avatar
There's been a problem with the lnf's & a few other chevy cars with bad lock cylinders the dealership will fix it no problem it took them like 2 hrs after they got the car in the bar. There's also a post about this on here with myself & others it happened to
Old 07-07-2010, 06:51 PM
CRR
CRR's Avatar
Thanks, Alleynejl. I'm going to have my buddy clear the CEL before I go to the dealer. I should have just stalled the car in 5th gear to shut it off instead of unplugging the fuel pressure fuse to shut it off. It doesn't hurt the car but atleast the CEL wouldn't have came on if I did it that way. Hopefully, they don't hook there **** up to my computer and check for a tune! I just want them to fix it, plain and simple. Nothing else! I know this issue has nothing to do with an aftermarket tune, but you guys know how some dealerships can be. They're just itching to void someones warranty.
EDIT: I just hit up McDonald's for some dinner and the CEL cleared itself. This time, I stalled the car to shut it off instead of pulling the fuel pressure fuse to shut it off. I'll keep you guys posted on what GM says about it.
Old 07-10-2010, 02:08 PM
CRR
CRR's Avatar
I just got my car back from GM this afternoon. Everything is good now. They said that they had to replace the ignition cylinder assembly or something along those lines.
Gugi96
09-15-2015 12:24 AM
Wind
09-11-2015 06:57 PM
brickloaf
09-06-2015 05:55 PM
Quick Reply: Key stuck in on position! Car can't be shut off!
