I cant remove my starter!!!
Old 04-28-2010, 09:28 PM
SloBaltS/C's Avatar
either im a dumb guy or just cant get my starter off help?
Old 04-28-2010, 09:39 PM
Deathscythe's Avatar
There's a problem that you won't like. The bolts that mount the starter up to the transmission are inside the bell housing.
Sorry. And have fun with that.
Old 04-28-2010, 09:40 PM
1fastSSBalt's Avatar
Wow, gotta love the engineering design on that xD
Old 04-28-2010, 09:43 PM
I thought it was stupid too, but that's the way it's secured to the block when I put my engine back together.
Old 04-28-2010, 09:44 PM
SloBaltS/C's Avatar
guys HELP PLEASE NOW IM CONFUSED
Old 04-28-2010, 09:51 PM
Not sureo n the year of your car...I would say google it? But from what he is saying, you have to get inside your transmissions belhousing to remove the necessary bolts in order to remove your starter.
Old 04-28-2010, 09:53 PM
SCcobaltSS's Avatar
My starter came off from two bolts on the outside of the bell housing.. I am confused too.
Old 04-28-2010, 09:54 PM
Maybe it differs per year? Idk i haven't had to take my starter off for any reason yet =)
Old 04-28-2010, 09:56 PM
My ss/sc is an 07. I don't think they would change the design in the middle of the cycle for the lsj. Look at the build book for the lsj. It'll explain where it goes with pictures so you can see for yourself.
Are you talking about the starter or the solenoid.
Old 04-28-2010, 09:58 PM
SCcobaltSS's Avatar
Am I thinking of the wrong thing here?
Old 04-28-2010, 09:59 PM
What year is yours?
Old 04-28-2010, 10:00 PM
SCcobaltSS's Avatar
06.. That is the starter and it cam out from the outside of the housing.
Old 04-28-2010, 10:03 PM
Now that I think about it, you're right. I was thinking about the water pump bolts that are a pain in the ass to get to.
By the way, have you gotten yours running yet?
My apologies to the OP. Is your view of the starter restricted in any way?
Old 04-28-2010, 10:07 PM
SCcobaltSS's Avatar
No mine has not got started. Waiting on reply from Maven and others.
I thought water pump was the same way. But I didnt unbolt mine, the machine shop did to sleeve it.
OP see pictures, it should help? The solenoid should not be engauged so its easy to pull out.
Old 04-28-2010, 10:09 PM
Well, best of luck to you and the OP. I just fired mine up the first time sunday night.
Old 04-28-2010, 10:10 PM
SCcobaltSS's Avatar
Lucky you.
Old 04-28-2010, 10:19 PM
shadowfaxss's Avatar
The pics are an excellent illustration of where the starter mounting bolts are. It doesn't matter what year you have; there are two bolts on the outside of the bell housing. I've done several and different model years.
The top bolt will require and extension using a 3/8 drive ratchet, 13 or 14MM.
Old 04-28-2010, 10:23 PM
SCcobaltSS's Avatar
Glad I could help. Atleast my build pictures helped someone.
Old 04-28-2010, 10:41 PM
Lucky you.
****, it's been too long anyway. Try being without your only car for eight months.
Old 04-28-2010, 10:52 PM
SCcobaltSS's Avatar
Holy ****!
Old 04-28-2010, 10:54 PM
September 5 2009. It was largely because of what happened the first time it was built.
Old 03-02-2013, 11:54 AM
TxLonghorn#1's Avatar
What is the best/easiest way to remove the starter? I need to do this ASAP......like right now! Someone please help me
Old 03-02-2013, 12:04 PM
574's Avatar
The best way to get at it is with the IM off. Took my starter off in 2min
Old 03-02-2013, 12:09 PM
Sorry for being a nube....what is IM?
Old 03-02-2013, 04:35 PM
Ok so I removed the "hidden" bolt that was on the passenger side of the IM(intake manifold) and the IM still is coming off. Is there a bolt at the bottom of the IM to where i need to get under the car or on the driver side that needs to come off?
Quick Reply: I cant remove my starter!!!
