Transmission Swap
Old 04-05-2010, 03:29 PM
intel's Avatar
Transmission Swap
Hello,
I am planning on doing a transmission swap and I was searching the forums as to what can interchange (directly bolt on) to a Cobalt LS 2006 2.2L manual.
I found this first forum that states that the Cobalt LS transmission can be directly swapped with and F35 Transmissions.
https://www.cobaltss.net/forums/show...5+transmission
The second forum I found though says that the Cobalt LS transmission can only be interchanged with other 2.2L/2.4L models
https://www.cobaltss.net/forums/show...f+transmission
And searching on the forums, I am under the impression that the Cobalt SS/SC and the Cobalt SS/TC all use the F35 transmission but just have different gearing ratios..
http://en.wikipedia.org/wiki/F35_%28MU3%29_transmission
So my question is will a LNF or LSJ transmission fit on my Cobalt LS 2.2L ?
I was planning on getting the LNF transmission with a LSD from -
http://www.crateenginedepot.com/stor...P1907C437.aspx
Thanks-
(I did not know whether to post here or on the transmission forum)
Old 04-05-2010, 03:33 PM
Haz l33t wheelz.
ls1fbody's Avatar
it will physically bolt up to the block. This topic has been covered MANY times.
You'll need a new clutch/flywheel (given they even mate up considering dimensions etc.)
new master cylinder?
TOB
axles
mounts
intermediate shaft?
linkages
shifter
shifter base etc.
More work than it's worth to be honest.
Old 04-05-2010, 03:34 PM
RecklessL61's Avatar
sub to find out anwser also
Old 04-05-2010, 03:55 PM
intel's Avatar
Yea, I knew I was going to need a new master cylinder, clutch, and flywheel.. those were obvious.
I did not realize that I would need a new axle though, that was one thing I did not account for. ><
Can I get any insight from people that went this route?
Old 04-05-2010, 03:57 PM
AWD > FWD
TommyP's Avatar
see that's the problem, no one has gone that route, everyone decides that it's not worth it.
Haz l33t wheelz.
ls1fbody's Avatar
nobody has gone this route.
Old 04-05-2010, 04:02 PM
intel's Avatar
Thanks for the help. I am too then deciding it's not worth it then lol
Old 04-05-2010, 04:16 PM
koch1ar's Avatar
u can buy a LSD to put in your trans or you can even buy a brand new 2.2 trans with lSD already in it
Old 04-05-2010, 08:09 PM
intel's Avatar
Yea I am just thinking of getting a transmission with an LSD in it, as a standalone LSD insert is almost just as much
Old 04-06-2010, 08:40 AM
kxrida2000's Avatar
Where can you buy a 2.2 tranny with an lsd already installed?
Old 04-07-2010, 01:39 PM
flyy's Avatar
Old 04-07-2010, 01:53 PM
conerboner's Avatar
it says lnf? will it work?
Old 04-07-2010, 03:27 PM
Haz l33t wheelz.
ls1fbody's Avatar
No, that's for the lnf, not 2.2.
Old 04-07-2010, 06:21 PM
kxrida2000's Avatar
what about this one?
http://www.crateenginedepot.com/stor...P1886C437.aspx
Old 04-07-2010, 06:30 PM
Haz l33t wheelz.
ls1fbody's Avatar
Looks like stock photo's. I would call CED and ask before ordering.
Old 04-07-2010, 06:36 PM
kxrida2000's Avatar
alright thanks im broke for now just finished getting all my parts together for a 400+ hp turbo build on my 2.2 but i will most likely be needing this in the future.
Old 04-08-2010, 12:25 PM
BLKLS's Avatar
The hhr f23 has a 4.11 final drive.
Old 04-14-2010, 11:35 PM
elecblue06's Avatar
TOB
axles
mounts
intermediate shaft?
linkages
shifter
shifter base etc.
why
mvp was able to use a 2.4 block in an LSJ.. he got a custom flywheel made.. but he didn't need too .. everything bolted right up
and there are f35 flywheels that'll work with the 2.2/ 2.4
Old 04-14-2010, 11:46 PM
koch1ar's Avatar
thats the one i was talking about. dont see why it wouldn't work lol
Old 06-02-2010, 04:11 PM
stangetr's Avatar
any update on this? i'm thinking abou tdoing this to a 2.4- upgrade to the tc/ss trans
btw- its not only the lsd- when you upgrade to the turbo trans, you end up with-
bigger axle's, larger wheel bearings, quicker steering ratio, stronger knuckles...... oh and limited slip-
in my book this is a well worth it mod, but of course so many people here will try and discourage those with good ideas-
try it man and let me know how it goes
Old 06-03-2010, 12:38 AM
joshc.'s Avatar
Well seeing as there is a LS61(LSJ bottom end/L61 head) cavalier with the F23, the key was using the F35 spacer. It will bolt up no problem since the bellhousing bolt pattern is the same across the ecotec line.
Old 06-03-2010, 01:03 AM
elecblue06's Avatar
so in theory you could use the F35 spacer and be able to keep everything else stock? with the F35 flywheel?
and an L200 clutch?
Old 06-03-2010, 01:54 AM
joshc.'s Avatar
Yes in theory, I believe the guy running that setup was running an LSJ clutch with the F23 and the spacer helped clear part of the bellhousing since the flywheel/clutch was contacting when he was turing it over. So there might not even be use for the L200 clutch, or spacer it just needs to be mounted and tried. The spacer is there for TOB to pressure plate clearance from what I've read.
Old 06-07-2010, 01:08 PM
stangetr's Avatar
any ideas who has done this swap?
Old 06-07-2010, 02:04 PM
joshc.'s Avatar
He goes by Daflyinskwirl on a couple of different forums but take into account he is using an LSJ block with a F23. Where as your trying a L61 with a F35, for all purposes its possible and will bolt to the engine but there are other parts that would need to be changed.
What I would do is buy an F23 and F35 and start comparing gear ratios and final drives and piece together a tranny. That way you could use the F23 case and not have to switch up so much, if you used a F35 diff you would need a hybrid axle but thats not too hard.
Quick Reply: Transmission Swap
