my key fob won't work anymore...
Old 09-29-2009, 03:45 AM
InitialG's Avatar
I have a problem with my key fob, one night it was working then the next day it just stopped. I thought it was because of the battery inside being dead but that wasn't the case. Or at least I think it's not anyway, is there anyway to reset it or something? I really don't want to take it to a GM dealer to get this stupid thing fixed.....
thanks in advance.
Old 09-29-2009, 03:52 AM
stacy_dammit's Avatar
Hmmm, some what of a similar situation, but for me it was the battery, had it for 2 years on original battery from day of purchase.
Umm, didnt you get a second key w/ fob (spare), use that one.
Last edited by stacy_dammit; 09-29-2009 at 03:52 AM. Reason: Automerged Doublepost
Old 09-29-2009, 03:54 AM
InitialG's Avatar
hmm, did you have to do anything special after putting in a new battery? Or does it have to be a certain name brand? The only thing I know for sure is that I know I have the right type, I bought the 2032 battery.
and no, they only gave me one fob.
Old 09-29-2009, 04:00 AM
Yeah, thats the one, nothing special to do. Just replace, and should be like new. If not, maybe you got water on it.But I doubt that would affect it because I've dropped mine in a big puddle of rain water and no problem.
Old 09-29-2009, 01:31 PM
InitialG's Avatar
Well, I never dropped it in water or anything like that. I have, however, dropped it on the ground a few times here and there. Would that have caused it to not work anymore? I'm looking at it right now on the inside and nothing looks like it's broken off or anything. Weird...
Old 09-29-2009, 03:53 PM
SCcobaltSS's Avatar
Well my solder came lose to the battery connection twice on mine. Pull up lightly on the metal where the battery sits and connects. Does it move?
Old 09-29-2009, 05:00 PM
InitialG's Avatar
I don't my keys on me right now, but when I do check it. If it moves what does that mean? That I need to get it tightened or glued??
Old 09-29-2009, 05:11 PM
rallyracer's Avatar
I was the the dealer the other day and some lady had to buy a new key fob. They told her that replacing the battery wont fix it. They told her when the battery runs you you need to purchase a new fob and also pay to have it programed...which was around $100 total.
I asked her (when the guy went to the part) if she tried to just replace the battery and she said she did but that it didnt do anything.
Old 09-29-2009, 06:25 PM
ddsscobalt's Avatar
I had to re-solder the metal clip thingy that touches the battery.. Mine stopped working and when i took it apart the solder had broken and the metal piece was just sitting there... check that metal retainer clip
OTHERWISE... it may be another FML kinda thing haha
Old 09-29-2009, 06:38 PM
InitialG's Avatar
well..it looks like it's an FML type of thing because everything looks like it's intact..um, what if I were to buy an aftermarket alarm with an unlock feature with it..would that work? Because I don't feel like spending $100 on a factory one...might as well spend the same amount on one that's probably better.
Old 09-29-2009, 06:43 PM
utsadude's Avatar
To fix mine I just put a piece of paper folded a couple times between the plastic back and the battery bracket.
Old 09-29-2009, 07:00 PM
InitialG's Avatar
well, I guess I can try that.
Old 09-29-2009, 07:52 PM
sscharged07's Avatar
mine also just came loose on the inside. (the part that holds the battery in place), i just took it apart and wrapped it real tight in electric tape. Perfect ever since.
10-27-2015 01:27 PM
dennis69
10-20-2015 04:49 PM
SSLOW06
10-01-2015 07:21 PM
OrangeCoba
09-25-2015 06:06 PM
Quick Reply: my key fob won't work anymore...
