Clicking noise in steering ..
Old 05-27-2009, 07:10 PM
ziggity's Avatar
When im stoped if I turn the wheel left and it makes a clicking noise ... any idea what it might be?
Old 05-27-2009, 07:58 PM
Permafried-'s Avatar
You're sure it's not just the power steering kicking in since there's a large amount of play in the wheel when you're stopped that's essentially a deadzone? Just a thought.
Old 05-27-2009, 09:59 PM
ziggity's Avatar
Nah this is the first time it has ever done it.
Old 05-27-2009, 10:29 PM
outtamymind's Avatar
fyi our cars don't have power steering. we use an electric steering system. and the clicking is most likely your intermediate shaft
Old 05-27-2009, 11:41 PM
xxxxsh4d0wxxxx's Avatar
Yeah, apparently the intermediate steering shaft on these cars is a ******* terrible design.
Old 05-28-2009, 02:01 AM
ziggity's Avatar
Something that has to be fixed right away or get it fixed when I can?
Old 05-28-2009, 02:05 AM
Doh
Doh's Avatar
It's probably moderately high on the priority list (correct me if i'm wrong)
I've had mine replaced two times in a year. And I swear it started doing it about an hour after it was replaced the second time. *This was like 6 months ago*
So i've just said **** it for now and i'll bring it back in when I have to for something else.
Old 05-28-2009, 08:16 PM
you can take your time but i would get it done sooner then later. and ya they are a horrible design for alot of gm vehicles not just the cobalts
Old 06-02-2009, 11:53 PM
nightridderSS's Avatar
Is there any upgrade for that
Old 07-23-2009, 04:33 PM
ziggity's Avatar
Brang it in a few weeks ago, getting a new steering column put in tomorrow.
Old 07-24-2009, 12:32 AM
there is supposed to be an upgraded steering column, i apparently have it and i tell ya its not nearly as bad as the stock one.
Old 07-24-2009, 10:36 PM
ziggity's Avatar
Yeah hopefully i get that then ... so I had an apointment at 8 and they call me at 4 and tell me they didnt get a chance to get in.. shitty service
Old 07-25-2009, 09:53 PM
it happens. it happens at the shop i work at, and i'm busy all day and all the other techs work as much as they can, its the advisors that don't realize that they've overbooked.
Old 07-25-2009, 10:06 PM
ziggity's Avatar
I know I already had it in last time though and they told me the same thing and now the same thing again and I had the apointment for about a month .. aww well ill get it done eventually ... little off topic but i seen in another thread you giving some advice on installing an intercepter ... whats the best way to do this? I should have mine this week and im not sure exactly how to install.
Old 07-25-2009, 10:30 PM
well have you ever installed any basic aftermarket electronics such as a single led or a switch?
Old 07-25-2009, 10:34 PM
ziggity's Avatar
Nope this is going to be my first mod on my car and this is my first car lol i seen some pics though doesn't look too hard and i'll get someone to give me a hand that knows more then I do but I was jw whats the best way to go ... just use the power wire from the stock boost gauge?
Old 07-25-2009, 10:37 PM
no some people say its ok but those electrical systems are meant for whats on them and really not much more so i don't like doing that, rather i would go and get a mini make-a-fuse and use that to tap into a fuse slot that isn't in use. and use that to run your power wire. also since the interceptor comes with the jumper installed and is not needed for proper operation with the cobalts remove the jumper on the back of the gauge and thats really it. everything else is pretty straight forward.
Old 07-25-2009, 10:41 PM
ziggity's Avatar
so just need the fuse and thats it? Certain slot?
Old 07-25-2009, 10:44 PM
slot 22 should be empty with nothing on it. there is a diagram on the panel you remove to get to the bcm fuse panel
Old 07-25-2009, 10:46 PM
ziggity's Avatar
Where at inside the car is the fuse panel?
passenger foot well inside trim panel. there will be a little lightning bolt on it.
Old 07-25-2009, 10:49 PM
ziggity's Avatar
But im not using my boost gauge anymore so would that matter? Wouldn't the power cable for that be sufficient?
Old 07-25-2009, 10:51 PM
you could but like i said i don't recommend it.
Old 07-25-2009, 11:56 PM
ziggity's Avatar
Ok thanks for everything , when I install it if I have any problems ill just post it back in this thread.
Old 07-26-2009, 01:33 AM
sounds good to me
Solaris99
28
03-15-2017 01:22 PM
biniecki
10-25-2015 02:23 PM
TedSS
26
10-10-2015 04:30 PM
jimbofug007
10-02-2015 12:06 PM
DANRICKARD
10-01-2015 12:08 AM
Quick Reply: Clicking noise in steering ..
