Rapid Clicking Noise From Inside The Dash
Old 01-13-2009, 07:54 AM
BAE 557's Avatar
On my 2007 SS, whenever I first start the car there is a loud rapid clicking noise coming form inside the dash on the passenger side. The clicking noise lasts for a second or so then stops. Has anybody else experienced the same issue, if so, how did you fix it? Unfortuantely the car is out of warranty, 40K miles.
Thanks,
-William
Old 01-13-2009, 07:57 AM
brickerenator's Avatar
Maybe it's the squirrels inside the engine stretching
iono
Really though, i haven't heard of this
Old 01-13-2009, 08:02 AM
Rattlesnake Race Shop
USMCFieldMP's Avatar
Sounds like it might have something to do with the HVAC system... I dunno. There are too many different types of "clicking" to diagnose it with the information that you have provided.
LOL!
Old 01-13-2009, 08:03 AM
my a/c fans clicks
Old 01-13-2009, 08:19 AM
williamhvx1's Avatar
A Time Bomb
Old 01-13-2009, 09:27 PM
BAE 557's Avatar
It actually sounded like it was coming from the location of the air bag. Of course when I got access through the glove compartment, the clicking decided to stop, at least for now.
Old 02-17-2010, 09:23 AM
light'bolt's Avatar
I'm just curious, did this ever get resolved? I'm having the same issue.
Old 02-17-2010, 09:32 AM
BK05SS's Avatar
Sounds like a HVAC issue, if your setting is one one, there will be a clicking noise in the car....hopefully that helps?
Old 02-17-2010, 09:53 AM
Illini_06SS's Avatar
This.
It's a pretty common issue. I had the dealer replace the blower motor on mine when it was still under warranty and it didn't help at all. I either just turn up the music or put the fan on settings 2-4
Old 02-17-2010, 02:05 PM
BK05SS's Avatar
yep, it sucks, whoever the boneheads who designed (or lack of design) the Cobalt and my 04 Malibu must have had some really questionable engineers with no customer involvement / foresight.
Old 02-18-2010, 02:19 PM
07ss_PJ's Avatar
Mine just started doing this too. Is there seriously no way of fixing this. I'm pretty sure it's a HVAC problem. I just changed the fuses the other day. Guess I'm going to have to pay the dealership to figure out what's wrong with it.
Old 02-25-2010, 05:12 PM
07ss_PJ's Avatar
Anybody figure this out yet? Also, my AC Control lights are messed up too. Can I replace the lights inside? At night the left side comes on but the right side is off. And I still have the clicking!!! Replaced the fuses already...
Old 02-25-2010, 05:26 PM
Gettinausernamesucks's Avatar
Get in your owners manual and see if your cars are fitted with a cabin filter. Its behind a cover behind the glove box. You have to unhook the glovebox to see the door. You could have a leave or somthing else falling down on the blower motor making the noise you hear. Pull the filter out and check for debris.
Old 02-26-2010, 01:21 PM
majourpain's Avatar
there was a thread about this a bit ago. it seems that the problem is a bad bushing/bearing that the hvac fan spins on. the only way to really have it fixed is to dealer it, beacuse the fan unit i believe is sealed. the way they replace the bushing/bearing is to cut it open and epoxy it lol
Old 03-22-2010, 04:08 PM
07ss_PJ's Avatar
So I replaced the cabin filter and it's still clicking. After doing a further inspection, the clicking noise is happening right above the cabin air filter. There appears to be another filter just a bit higher behind what looks like a honeycombed shroud. Don't know if that makes any sense. Anyone got a clue of how I can fix this or what to tell the dealership? I took a pic with my phone ...
Old 03-22-2010, 11:20 PM
07ss_PJ's Avatar
BUMP! Any help will do.
Old 03-24-2010, 11:52 AM
light'bolt's Avatar
The clicking I hear is not a fan. It only happens when I start the car. The sound is more of a switch turning on and off rapidly for about 1-3 sec. then it stops.
HVAC switch maybe??
Old 03-24-2010, 10:14 PM
07ss_PJ's Avatar
^Yes. Very annoying!
Old 03-25-2010, 01:19 PM
warrenb213's Avatar
hmmm like a click click click, sometimes up to 5 times mostly on startup but sometimes at stand still? if so your actually hearing something under your car towards the back. one of the emissions systems.
Old 03-25-2010, 01:29 PM
No, what's being discussed here is something in the HVAC system. It is only noticeable at fan speed 1, but slightly noticeable at fan speed 2. And 3 and 4 are just too loud to hear it over the noise. The clicking goes away completely if you shut off the fan.
Old 03-25-2010, 02:00 PM
07ss_PJ's Avatar
My problem is the same as light'bolt where it only happens when you first turn on the car and it's coming from that filter I took a picture of.
Old 03-25-2010, 06:52 PM
light'bolt's Avatar
no that's the trunk monkey, never could find that little bastard...
No that's not what we're talking about, I know that sound and it's been fixed. This is completly different because the fan is not on when I start the car.
What I need is a schematic of the cars wiring to see if there is a switch under there.....
Old 03-26-2010, 03:28 PM
07ss_PJ's Avatar
^ take your glove box off and right above the cabin air filter you'll hear and see where it's coming from. it's that filter i took a picture of. i don't know how to fix it though.
Old 03-29-2010, 09:08 AM
Shogokuma's Avatar
i had something similar but me it was my stereo, making noise in the tweeter on the passenger side
Old 08-09-2011, 04:54 PM
booda_33's Avatar
I just figured out what is causing the noise...hit the recirculation button
Quick Reply: Rapid Clicking Noise From Inside The Dash
