Did you Disconnect the Battery Before Installing Your Intake?
Old 08-10-2008, 04:27 PM
wardzach2007's Avatar
1.) Okay, I know many people have different Opinions. But are you supposed to disconnect the battery before installing it?
2.) And also, did YOU disconnect the battery before you installed it? And did you experience any CEL's?
Old 08-10-2008, 04:33 PM
JohnnySasakiMGS's Avatar
Its a good idea to disconnect your battery. I always have. I helped install and Injen intake on my friends 06 Si and he got a CEL. I disconnected the battery and it went away.
Old 08-10-2008, 04:34 PM
red06s/c's Avatar
i didnt disconnect it, and ive had mine for about 2 years with no problems.
Old 08-10-2008, 04:38 PM
You dont really have to take it off either. The computer will automatically relearn everything anyway. You really only need to disconnect the battery if you get a cel.
Old 08-10-2008, 04:40 PM
hmmm, interesting. Thank you so much guys.
red06s/c's Avatar
Hows your car <<< pic over there
Old 08-10-2008, 04:44 PM
auggie_ss_phx's Avatar
x2 same here
Old 08-10-2008, 04:47 PM
In my 05 ss/sc, when i installed the K&N filter, i disconnected two things from the air box. One was the big MAF, and I dont know what the ohter one was. DOes anyone know? It was a small box connector to the box.
Old 08-10-2008, 04:51 PM
lsjwannabe's Avatar
I did not when i installed mine
Old 08-10-2008, 04:53 PM
PinaSS's Avatar
i disconnected my battery after the install for about 10 min. then reconnected and started the car.
Old 08-10-2008, 05:09 PM
RooTBeeR's Avatar
i did not disconnect the battery and have not had any cel's (had it on for over 2,000 miles in less than 1 month) ...also I have the RAW 3"
Old 08-10-2008, 08:15 PM
Apcsox's Avatar
its one of those precautionary measures when working on a vehicle...... if you read say, a haynes or chiltons manual... it even tells you to disconnect the battery when doing arbitrary tasks like oil changes
Old 08-10-2008, 08:16 PM
Fire_Starter's Avatar
I didn't and no problems arised.
Old 08-10-2008, 08:18 PM
wordsthatiwrote's Avatar
Battery should be disconnected for any kind of work IMO. Better to play it safe I suppose.
Old 08-10-2008, 08:20 PM
OrngBalt's Avatar
no battery disconnect, no CEL, installed intake 20,000 miles ago
Old 08-10-2008, 08:33 PM
Black07SS's Avatar
waste of time you wont get a cel
Old 08-10-2008, 08:36 PM
theneelster's Avatar
1)Yes
2)No...I'm too lazy. No Cels.
Old 08-10-2008, 11:58 PM
It isnt a waste of time. Its actually a precaution that someone would take so that they dont accidentally short out something and cause electrical damage.
For a poor example; You go to change the rotors on your car and you obviously grab them with your hands to put them on. One should spray brake cleaner on them to remove all the oils from your hands. Its not necessary, but you do it as a precaution so you dont slam your car into something.
Old 08-11-2008, 12:02 AM
OriGinaL Condo's Avatar
I did it just incase.
Old 08-11-2008, 12:06 AM
JPizzle's Avatar
Nope. I didn't probably should have just to make sure nothing got screwed up. But you live & you learn...
Old 08-11-2008, 12:08 AM
I mean, lets say you didnt, and your CEL came on. What do you do? Disconnect it then, then the CEL should go away? Or is the CEL going to be there every time that intake is on there?
Old 08-11-2008, 12:09 AM
JPizzle's Avatar
If you disconnect the battery, after you get a cel, and reconnect the battery, start up your car & run it, the cel should never reappear again.
Old 08-11-2008, 12:10 AM
If its the wrong size intake. IE using an intake designed for a 2.2 application on a 2.4 I got a cel even after the negative disconnect. As one said before me. Live and Learn.
Old 08-11-2008, 12:11 AM
Oh, okay...
How do you disconnect the battery? Remove the red (positive) or black (negative) first? Red one right?
Im a noob, yes I know. But I havent done this since Auto tech.
Old 08-11-2008, 12:12 AM
NamedGobalt's Avatar
I didn't remove the negative from the battery. Of course I have a CEL from when I put my full exhaust on.
Quick Reply: Did you Disconnect the Battery Before Installing Your Intake?
