Turn Signal Problem?
Old 01-28-2006, 11:51 PM
JoeSS's Avatar
The other day I got into my Cobalt for the first time in about a week, I drove it around and I was going to turn right onto an intersection. I had my radio on and I thought I heard a fast clicking noise. I looked down and my turn signal is blinking twice per second.
I do know that this is something that needs to be serviced, but has anyone else had this problem? And does anything affect it? The only thing I did was change my headlights and disconnect the battery when not driving because of the cold weather. Any advice would be greatly appreciated. Thanks!
Old 01-28-2006, 11:54 PM
Chevypowered's Avatar
Sounds like either your front or rear turn signal bulb is burnt out or disconnected, go out and check it out.
Old 01-29-2006, 12:09 AM
JoeSS's Avatar
Checked them both out, all four lights work. Service manager doesn't know where it came from...
Old 01-29-2006, 12:12 AM
p7x
p7x's Avatar
if it keeps doing it, change the bulb, if you havent already done so.
Old 01-29-2006, 12:13 AM
Could be your turn signal relay that has gone bad, try swapping you relays and see if it happens on the other side
Old 01-29-2006, 12:19 AM
JoeSS's Avatar
I think the relay for both my left and right signal is bad. When I turn on my hazards, which I know is a different relay, they work fine. But both of my signals flash extremely fast.
Old 01-29-2006, 12:46 AM
tinyone's Avatar
i had a problem with mine too but we found out that both tail light sockets were bad and that they had to order them, that sucks, also i lost all int. lights as well ever the guage lights. i have not had the car in 4 days, the reason its taking so long is the cant just order the sockets its got to be the whole tail light i hope i get it back on monday
Old 01-29-2006, 01:32 AM
WopOnTour's Avatar
There is NO turn signal relays or flasher for the Cobalt signal lights (or a great many other cars/trucks for that matter).
Basically the BCM controls the turn signal bulbs directly based on input from the turn signal and hazard switches. If you have GOOD STOCK PN# BULBS installed AND there are no blown fuses present in the fuse panel located on the RH side of your console (techncially a "smart" fuse panel aka the BCM!) Then you should take it in to your service dept as there are likely DTCs present in the BCM that will indicate what might be wrong.
WopOnTour
Old 02-04-2007, 02:09 PM
blktrax's Avatar
Mine just devloped the same problem, last night I switched my headlight bulbs.
Took it out fora drive to align the lights, used the turn signals.
Took it out the next morning, drive into down got luch, drove home. About 30 min drive time in town and I always use my signals. Pullin back on to my street make a right turn.
Got the fast click , figured that the bulb got shocked when I had the headlights out.
In the garage with the headlights on and parking lights on BOTH filiments in the passenger side turnsignal bulb are lit, no blinking. The driver side operating normaly.
Horay service department tommrow.
Old 02-05-2007, 10:22 PM
blktrax's Avatar
Well dealer ordered a BCM and a new headlight assembly for mine, we shall see if that fixes it.
06MetallicBalt
08-17-2021 03:40 PM
Solaris99
28
03-15-2017 01:22 PM
Tupp
2.2L LAP Performance Tech
01-02-2016 12:04 PM
Adiaz1ss
09-26-2015 11:51 PM
roth
09-26-2015 12:16 PM
Quick Reply: Turn Signal Problem?
