Finally: Organized F35 transmission fluid thread
Old 06-11-2011, 02:44 AM
  #76
goeckeritz123's Avatar
Would you guys recommend chevy fluid or is their something better
Old 06-12-2011, 07:33 PM
  #77
xxxxsh4d0wxxxx's Avatar
Definitely stick with the fluid I linked you to.
Old 08-23-2011, 07:36 AM
  #78
Sweetsandman's Avatar
bumpity
Old 08-31-2011, 08:42 PM
  #79
Gelladuga69's Avatar
Bump Again.
Was looking for a transmission fluid thread, as some of mine leaked out during my clutch change.
Have to change it now and this thread had all the information I needed.
Mods, please sticky.
Old 09-01-2011, 02:14 AM
  #80
I went to the dealer and this is what they gave me part number 88861800
Old 09-01-2011, 02:18 AM
  #81
Im thinking its the wrong stuff cuz it was only $7.50 a quart
Old 09-01-2011, 11:02 PM
  #82
Maven's Avatar
yup, thats 2.2/2.4 fluid
Old 09-02-2011, 08:32 PM
  #83
You want part# 88862472
Old 10-02-2011, 09:08 PM
  #84
Nothin Stock
gotboost?17's Avatar
nice write up. couple questions, my cars been miss shiften and then stalled on a dyno, i have no idea how to check the fluide, do u think the fluide is shot.? car has 37,000KMs on it
Old 10-03-2011, 09:58 PM
  #85
Shouldn't be - No. Not in that short of a life-span. Did you check the roll pins? Or verify all of the linkages are connect correctly, nothing visually is broken? The shifter assembly on the top of the trans functions properly?
Old 10-07-2011, 08:54 PM
  #86
CrateEngineDepot's Avatar
Help me shift parts
I saw this thread and thought it was a great idea.
This is just a normal wear and tear siduation and since there parts that will help this why not put together all the items in one place.
55563732 LSJ Shift Cable Cable Upgrade Bracket
Get a firmer shift feeling with this upgraded support bracket.
Fits all Cobalts and Ions with LSJ engines.
Click here to order
90490900 Ecotec 5sp Shift Cable Roll Pin
Click here to order
88862472 Manual Transmission Fluid (SAE 75W-85) (API GL/4) (1 QT).946L
A 5-SPD MAN/TRANS(MU3),SATURN, COBALT(WDA) FLUID, M/TRANS (SAE 75W-85) (API GL/4) (1 QT)
Priced per quart
2 quarts required per MU3 Transmission.
Click here to order
or to order all 3 at once Click here
LMGYuwaku (10-23-2022)
Old 10-08-2011, 06:08 PM
  #87
rivaladore's Avatar
Nice didn't know you guys had roll pins. Wish I knew that when I got tc struts from you guys last week. Gonna be picking up two roll pins and two quarts of trans fluid. No dealerships have the ss trans fluid within an hour and a half of me.
Old 10-08-2011, 07:48 PM
  #88
no worries.
Old 10-08-2011, 11:30 PM
  #89
When did you guys stock roll pins? A while ago I tried finding a part number and searched online for the longest time.
I ended up ordering "Upgraded GM Racing" roll pins from John Powell.. Not sure the difference, or if there is even a way to tell.. I just kind of took his word for it.
Old 10-09-2011, 06:04 AM
  #90
727
727's Avatar
sorry. What's about 75W90 SHC Mobil ... for MT?
Old 10-21-2011, 10:19 PM
  #91
Black SS/SC 06's Avatar
Stickied
Old 10-22-2011, 04:02 PM
  #92
We have had the roll pins for a few years now, not sure what or if there is a difference from what JP sells.
Old 10-23-2011, 01:24 AM
  #93
rivaladore's Avatar
Just got the fluid and roll pins from you guys, now I gotta grind down a damn 8mm Allen wrench to fit in between the subframe and the drain plug. God damn it first changing something as easy as a thermostat was a bitch and now a stupid drain plug is a hassle wtf lol. Nothing is ever easy on this car.
Old 10-23-2011, 09:28 AM
  #94
I always read about people having to grind them down. Why not go out and buy a single wrench in the size you need, in a shorter version? I've got a long set and a stubby set.
Old 10-24-2011, 12:15 AM
  #95
rivaladore's Avatar
I looked at the auto parts store and didn't see any really shallow Allen wrenches
Old 10-29-2011, 02:14 PM
  #96
68Vette's Avatar
I've located the drain plug but where is the fill at????
Old 10-30-2011, 04:24 PM
  #97
Up and to the right of drain. Might not see it, cause of the dirt. Same allen wrench looking plug.
Old 10-31-2011, 01:42 PM
  #98
68Vette's Avatar
Thanks!!!
Old 10-31-2011, 01:51 PM
  #99
Thanks!!!
No problem, glad you found it.
Old 11-16-2011, 10:59 AM
  #100
juice3's Avatar
subd
Quick Reply: Finally: Organized F35 transmission fluid thread
